Results 1 to 4 of 4
Thread: Check engine light
    Aug 2014
    Check engine light
    Hi guys, a few weeks ago I replaced my leaking injector oil seals. I removed the inlet manifold and had it cleaned etc. After putting everything back together, my engine check light came on. I got my local Nissan dealer to put their scan tool on it and it came up with EGR code found. They said I need a new egr and all gaskets and wiring harness to be checked as well. I bought a second hand egr from the wreckers and new gaskets and engine light still comes on. What should I be looking for apart from broken/melted wires etc. I’ve also replaced fuel, oil and air filters new oil, maf sensor cleaned.
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    G'day mate and welcome to the forum.
    @AB @Doggy @mudrunntd @Growler someone want to shift this to the mechanical section so he gets a bit more help[
    Apr 2013
    Is the egr blocked off at all? My engine light on my commonrail zd30 comes on a fair bit then goes comes back etc since blocking the egr, scan tool says it's egr but iv been told its normal once doing the block for a crd
