Must be blocked i took the line completely understand off the master cylinder and no fluid comes out when i pump it, if there was a problem with the vacuum setup then would that make the brakes play up aswell given there on the same vacuum line because the brakes are fine?
Sent from my CPH1701 using Tapatalk
Would be solving your master cyl prob first up.
As mudnut suggested:
maybe it is time for a new system, or a good one from the wreckers
Anyway remove your master cyl have a good look then decide on replacement.
