Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Battery terminal "double adaptor"
    Beginner Thepower's Avatar
    Aug 2017
    Waterford
    Quote Originally Posted by Brissieboy View Post
    Something like this (modified pic from the Ebay suggestion from earlier Yeti's Beast post):Attachment 73939
    May I ask the reason you need the above double terminal adapter?
    If you are looking for an adapter like that to add extra batteries there are adapter options out there with isolation switches to allow you to disconnect at will.
  2. #12
    Expert Brissieboy's Avatar
    Jul 2015
    Brisbane, Qld
    10 Post(s)
    Quote Originally Posted by Thepower View Post
    It just seemed an easy way out at the time to retain the existing connection and add a second with the same cable end which I already have. I musn't be the only one who ever wanted to do something like this as the double terminal battery option is available as pointed out by ET above. My second battery has the double connections (post and tab) but the crank has just the one.
    Yes, there are plenty of other options out there, but that was what I was my first thought.
    In any case, it doesn't look like such a device is available so it is probably time to re-think, or even fabricate my own if I really want to go that far. I'm really not going to lose any sleep over this.
  3. #13
    Legendary dom14's Avatar
    38 Post(s)
    Yeah, but you have been.
    Have a look at these ones. They should do the job with a ring lug.
    http://amelec.com.au/products/unilug...-lug-assembly/
    Or if you insist on battery terminal end looking type connector, then you can add this bit to the above and off you go.
    http://amelec.com.au/products/unilug...-adaptor-post/
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
  4. The Following User Says Thank You to dom14 For This Useful Post:
    Brissieboy (10th December 2017)
  5. #14
    38 Post(s)
    Or below ones if you can wait few months for it to arrive from China.
    https://www.ebay.com.au/itm/2-Pcs-Po...AAAOSwAHBaIlS9
    https://www.ebay.com.au/itm/Zinc-All...kAAOSwDrNZSj7k
    And these UNILUG ones on ebay Australia. They are obviously pricey.
    https://www.ebay.com.au/itm/2X-UNILU...sAAOSwXrdaF4IA
    https://www.ebay.com.au/itm/UNILUG-T...8AAOSwPIhaF4IC
    Try Jcar or Autobarn.
    Cheetah Outreach
  6. The Following User Says Thank You to dom14 For This Useful Post:
