Results 1 to 10 of 14
Thread: Battery terminal "double adaptor"
    Expert Brissieboy's Avatar
    Jul 2015
    Brisbane, Qld
    10 Post(s)
    Probably a silly question, but is there such a thing as a battery terminal double adaptor? Something that bolts onto the terminal and provides two post for connections. I haven't been able to find anything like this in the myriad of connectors available.
  2. The Following User Says Thank You to Brissieboy For This Useful Post:
    MB (2nd December 2017)
    Might be but I've not seen one.
    There is this if it suits your use tho https://vetco.net/products/knife-swi...nswitched-post
    Post to multiple terminal bolt up adapters are very common in pairs or even 4 or 6 terminal...
    Then there are the Battery themselves...
    Any amount of multiple terminal batteries (post and bolt AKA Group 31, post and thread or double thread) but dual post are very rare and the only one I've seen had the 2nd posts on the side so may be a hassle to mount assuming they are still made.
  4. The Following 2 Users Say Thank You to the evil twin For This Useful Post:
    Brissieboy (3rd December 2017), MB (2nd December 2017)
    Expert Yeti's Beast's Avatar
    Aug 2016
    Jimboomba
    4 Post(s)
    How about this
    https://rover.ebay.com/rover/0/0/0?m...2F152319679908
  6. The Following 2 Users Say Thank You to Yeti's Beast For This Useful Post:
  7. #4
    Jul 2015
    Brisbane, Qld
    10 Post(s)
    Thanks folks. Neither is exactly what I am looking for, but both are definite possibilities. The knife switch sounds like a good idea for the winch and looks like it will handle the load.
  8. The Following User Says Thank You to Brissieboy For This Useful Post:
    the evil twin (3rd December 2017)
  9. #5
    Aug 2010
    adelaide
    GO TO EBAY AND LOOK UP BATTERY TERMINAL CONNECTORS
    or this one https://www.ebay.com.au/itm/2PCS-Aut...gAAOSw~AVYoSLr
    OH LEATHER IS NICE
  10. #6
    Jul 2015
    Brisbane, Qld
    10 Post(s)
    Quote Originally Posted by my third 256 View Post
    Yep. Been there, done that.
    Did that early in my search but unable to find what I thought would be a common thing - a simple 'double adaptor'.
    Still haven't found them, but the earlier suggestions are workable alternatives if nothing shows up.
  11. The Following User Says Thank You to Brissieboy For This Useful Post:
    Yeti's Beast (4th December 2017)
  12. #7
    Beginner Thepower's Avatar
    Aug 2017
    Waterford
    Quote Originally Posted by Brissieboy View Post
    If the above suggestion by the evil twin /knife-switch-battery-disconnect-with-unswitched-post is not the type of battery terminal you are looking for then have a look at below URLs.
    https://www.ozautoelectrics.com/aerp...-terminal.html
    https://www.ozautoelectrics.com/19mm...r-outputs.html
    If that is not what you are searching for then it would be helpful if you can draw a sketch of the adapter and load it here.
  13. #8
    Aug 2010
    adelaide
    draw us a picture would be great or detailed explenation what you are after or want to do
    OH LEATHER IS NICE
  14. #9
    Jul 2015
    Brisbane, Qld
    10 Post(s)
    Something like this (modified pic from the Ebay suggestion from earlier Yeti's Beast post):terminal.jpg
  15. #10
    As prev posted, I've not seen a dual SAE Terminal Adapter.
    Quite a while back I did work on some Yank stationary plant that used this config https://www.expeditionexchange.com/o...y003%20008.jpg
    That type of battery case is readily available from most manuf, Optima, Exide, Platinum etc etc
    There is a rarer but more conventional version with both terminals on top (an SAE post screws into the pad to give twin Posts)
