Page 10 of 11 FirstFirst ... 891011 LastLast
Results 91 to 100 of 101
Thread: MIG with argon
  1. #91
    Legendary dom14's Avatar
    38 Post(s)
    dom in all honesty your 130 amp mig is going to struggle on anything over about 3mm,
    Yeah mate, and that's all I need atm. I would and can use the stick and TIG for thicker metal.
    All the metal tubing that I've been welding so far have been well under 3mm.
    Only reason I haven't got any work done from the 130amp gas MIG is 'cos I couldn't get it to
    work with pure argon, and that 'cos I have to be tightarse with spending another $300 on MIG gas.
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
  2. #92
    Expert billyj's Avatar
    gordon
    my point is that even down to 1.6mm steel you will be able to stick weld it if you get a bit of practice and use decent rods that freeze up fast, not just cheap nasty gp rods from bunnings
    gone to the dark side 2017 vdj 79 dc
  3. The Following User Says Thank You to billyj For This Useful Post:
    dom14 (29th November 2017)
  4. #93
    Just watched your mid without gas video.
    Turn the wire down. A lot. Like half what your on now so 2 to 3 maybe..
  5. The Following User Says Thank You to BigRAWesty For This Useful Post:
  6. #94
    38 Post(s)
    Pretty interesting, isn't it? Those ugly looking solid wire 'welds' without gas actually welded to the base metal fairly strong. It kinda works as long as I don't move the MIG torch & only hold it in one spot. So, it's kinda possible to do kinda strong weld tacks without gas with solid wire.
    Cheetah Outreach
  7. #95
    38 Post(s)
    Yeah mate, I've been stick welding 1mm and even below thickness pipes with stick welding, but it's time consuming as the hammering & scraping take up a fair bit of time. Also, it demands I wire brush the paint or gal off the pipes first, 'cos it easier to burn a hole through it when the paint or gal get in the way of controlling the heat. And I did with cheap sticks as well. Doesn't look good, but appears to be holding two pipes together.
    Cheetah Outreach
  8. #96
    Not really. It may look ok from the outside but if you have to cut it open it would look like an aero bar on the inside
    38 Post(s)
    Ok, cool. I guess you meant there will be hollowness to that weld tack and it is soft and weaker?
    Cheetah Outreach
  10. #98
    Yep. It'll be no good
  11. The Following User Says Thank You to BigRAWesty For This Useful Post:
  12. #99
    gordon
    doesnt matter what welding process you use you should be grinding off any paint,gal,rust or scale first regardless. and a wire brush will not remove gal or scale just polishes it
    without clean steel your just shooting yourself in the foot before you start
  13. The Following 2 Users Say Thank You to billyj For This Useful Post:
    dom14 (29th November 2017), GQtdauto (29th November 2017)
  14. #100
    38 Post(s)
    Ok, cool. I was using a heavy duty wire brush with an angle grinder. I thought it was removing gal with some elbow grease on it, but i reckon you're right. It can't be that easy, 'cos if the gal removes that easy, then that would defeat the purpose, wouldn't it?
    Grinding it will be from now on, but that means PITA extra and careful grinding work for me.
    I tried using gasless MIG today(with 0.9mm gasless wire and low setting with number 3 wire speed) on under 1mm thick mild steel pipes.
    It was way too easy to blow a hole through it. So much so, I would've had better outcome with stick welder with low amp.
    But, kept persevering to get it right. It is apparently more difficult to weld thin sheet metal with a gasless MIG than with a gas one,
    and particularly my Ozito one, which I think 'cos of the lack of amp/volt control(Only low and high settings). Nothing in between.
    The rest has to be controlled with wire speed & heat management/hand control.
    Cheetah Outreach
