Here is the video(s) where I did the 0.6mm wire without gas(pure argon)
This is amazing guys. I'm getting "better"(kinda) results without pure argon or any gas for that matter.
When I moved the gun, there was too much splatter(even though I moved and kept the gun almost touching the base metal or actually touching it with the nozzle).
The bead to the left is where I moved the gun(but didn't record in on video).
The 'bead' to the right is the one from the video where I got better results than with pure argon.
Now, I'm beginning to wonder whether there is a need for shielding gas at all, considering how bad the beads were with pure argon.
The weld tack I produced by keeping the gun on the same place was pretty strong. I couldn't get it off by hammering on it hard, whereas the pure argon shielded beads were able to remove with a flat screwdriver(without even hitting it).
https://www.youtube.com/watch?v=t_sv...ature=youtu.be
https://www.youtube.com/watch?v=bflp...ature=youtu.be
I'm pretty intrigued by the above result.
I think it's about time I try either with pure CO2 or argon/co2 MIG mix.
