Results 1 to 5 of 5
Thread: Speaker faulty in GUIV
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    I have a weird fault in my radio wiring (I guess). On a hot day everything works OK, but on cold mornings only the front left (passenger side) speaker works. In the summer by the end of the day they are all working. I have a fairly good knowledge of electrics but this one has me stumped. I have changed the head but still have the same issue. This means that I have either three speakers with the same problem, left front and both rear, or there is a fault in the harness or plug(s). Behind the radio there are two Nissan plugs, one set of speakers on each, so it would seem strange if the fault was there. Anyway I have plugged them in and out numerous time changing heads and attempting to isolate the fault, so it is unlikely that the fault is still the same. Does anyone know if there is another plug/socket or wire harness join behind the dash that might be faulty or loose? BTW, when the fault occurs, the speakers just fade out or in over half a second or so. There is no crackle or intermittent failure. As the day warms up, sometimes the rear and RH front just fade up to normal volume and tend to stay there for the rest of the day. Next morning I will be back to one speaker only. I'm at my wits end and no I'm not making this up. Help! @the evil twin @Yendor
    Mar 2016
    Nandewar Ranges, NSW
    10 Post(s)
    Quote Originally Posted by 4bye4 View Post
    Mine were more or less doing the same thing. Working one day & not the next, started with the front left, then the two rear went. Checked connections at speaker end with another speaker & had sound, so had to be faulty speakers. Not surprised after seeing the amount of dust inside the door panels, probably jamming the magnet in the speaker IMO.
    Ended up replacing all 4 & problem solved.
  3. The Following User Says Thank You to VK2FMIA For This Useful Post:
    4bye4 (25th November 2017)
    snip... I have changed the head but still have the same issue. @the evil twin @Yendor
    Jeez man... changing the head seems a bit of a drastic option, I would have at least disco'd the battery for 20 minutes first
    Sorry, couldn't resist.
    I agree with VK, as weird as it sounds it could well be multiple speakers.
    I would beg or borrow another speaker (almost any will do) and pop the trim off the offending doors and try jumping another speaker and seeing if it works
    Aug 2014
    Kingsley WA
    15 Post(s)
    All good and I’ve already disconnected, switched on and off again and all that stuff. Best result worked fora day then SOSO. Will probably go the new speakers all round option. Thanks E.T. and V K.
    3 out of four speakers in my guiv were cooked when i bought it, they could sometimes work and others not at all. i just replaced them all and now no more problems!
  7. The Following User Says Thank You to rusty_nail For This Useful Post:
    4bye4 (26th November 2017)
