Results 1 to 10 of 12
Thread: P/N Inhibitor - other threads don't have right info
    Expert tuckertrucker's Avatar
    Aug 2015
    Far North, New Zealand
    Evening all
    What is the location of the P/N start inhibitor relay switch?
    I know the actual switch is on the side of the gearbox, but this is just the switch that tells the truck where the stick is located. And I know where the start relay is (under the cover next to the driver side battery), but again, this is just the start relay.
    The inhibitor relay is the one that opens the start circuit when the gear shift switch says its not in park or neutral.
    Reason for asking - manual conversion. Need to bridge it. I can cross the neutral and live wire in the auto's loom to trick it into thinking its in neutral. But I would much prefer just to remove the relay. Wagon is a 1992 GQ Safari.
    cheers people
    1992 Nissan Safari Granroad LWB TD42 after market turbo RE4R03A (for now) 3" straight pipe
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    P/N inhibitor is on the side of the trans. It closes the circuit in P or N so the start relay can work.
    John
  3. The Following User Says Thank You to jff45 For This Useful Post:
    tuckertrucker (24th November 2017)
    84 Post(s)
    The manual pages EL 80 and EL 81 show the relay as 142 M under the cover next to the battery.
    Page EL17 shows which wires to bridge out, but the Haynes manual is a bit different.
    Edit that is for a petrol engine.
  5. The Following User Says Thank You to mudnut For This Useful Post:
    Aug 2015
    Awesome thanks! I wasn't sure if it closed the circuit or just sent signal to another relay near the passenger kick panel.
    Aug 2015
    I now see where I was getting confused - I was assuming that the start relay that uses the signal from the inhibitor switch was live with a constant 24v. But according to the diagram (if I opened my eyes and read correctly) it says that the inhibitor circuit is switched in the ignition circuit.
    So when the key is on, the P/N inhibitor switch will close or open the start relay, and the START position on the ignition switch energises the relay (which will only send power to the cranker if the P/N inhibitor closes the relay)
    So if I earth the WHITE wire, the relay will close when the ignition switch is moved to START, and the cranker will do its thing.
    The manual says that the brown relay wire is connected to ON or START. I don't know what variants the manual covers, but in mine, it must be connected to start. Considering if I bridge the two heavy wires, the engine will crank.
    Cheers for the help, i've had the manual for a few months but must have kept mis reading this page on account of it saying "gasoline engine models"
    84 Post(s)
    @tuckertrucker The Haynes manual page 16-12 shows the TD42. Yep, just earth the starter relay and bypass the switch altogether as per a manual transmission. I have amended post #3.
  9. The Following User Says Thank You to mudnut For This Useful Post:
  10. #7
    Aug 2015
    cool thanks. I don't have the haines manual dammit. Is the wiring the same for the two? I can't imagine why it'd have different wiring considering both are mechanical engines.
  11. #8
    84 Post(s)
    @tuckertrucker this should suffice. The two (petrol and diesel) are wired differently. M/T = manual transmission (black wire) . A/T = auto transmission (White wire which you can earth). This diagram is for TD42 1991 and later models. The second is for Carby engines. And the third is TB42 EFI. The fourth is a TB42 Carby auto.
  12. The Following User Says Thank You to mudnut For This Useful Post:
    GQtdauto (24th November 2017)
  13. #9
    Aug 2015
    so here's something interesting then - mine is auto, and its diesel. But it is certainly not wired like the haines manual says. The black and yellow wire going into the start relay is live with the ignition key ON. I know this because I crossed the two black/ yellow wire with the ignition on and the engine cranked. If it was wired as above, then the black/yellow wire will only be live when the ignition switch is in the start position.
  14. #10
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Quote Originally Posted by tuckertrucker View Post
    Maybe the difference between a safari 24 volt and non safari 12 volt .
