Depending on output and setup it shouldn't matter Westy I have tried all combinations over the last 20 plus years , we only use straight argon at men's shed with no trouble at all , if you had to choose one gas and one gas to cover all applications it would be argon .
Check with Dr google and you'll find it's a common diy gas , if you were only ever going to weld low carbon steel I'd probably go a mix but the cost these days for swap and go is the same .
Dom can do stainless steel with his Tig if needed so it's a better option imo.
