Results 1 to 10 of 45
Thread: Timing cover and backing plate removal
Threaded View
    84 Post(s)
    Just a quick fix for undoing the bolt. I used an impact socket with a breaker bar and a heavy bit of pipe. I wedged the breaker bar and pipe onto the concrete and briefly turned the ignition key to start. It cracked the bolt. This worked on the RB30, but it is a lot smaller than a TB or TD.
    To torque the bolt on an auto, place an old V belt on the harmonic balancer and twist it real tight with a bit of strong pipe. Slip a longer bit of pipe through and wedge it onto something solid.
    If done right, you should be able to torque the bolt to spec.
  2. The Following User Says Thank You to mudnut For This Useful Post:
    dom14 (22nd November 2017)
