Results 11 to 20 of 25
Thread: Welding gas bottles
    Legendary dom14's Avatar
    38 Post(s)
    Believe it or not but gasless mig actually works so much better using Co2 gas , that's why we had the bottle at TAFE but only used it as a demonstration , students never actually used it they used Argo shield .
    There was a way to get hold of CO2 dirt cheap from soft drink bottle plants.
    I'm not sure whether it's still a possibility.
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
  2. The Following User Says Thank You to dom14 For This Useful Post:
    GQtdauto (18th November 2017)
  3. #12
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    You'll be amazed at the difference .
  4. #13
    38 Post(s)
    You mean the difference between gasless and gas MIG?
    Cheetah Outreach
  5. #14
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Difference between gasless wire on its own and gasless wire with Co2 .
  6. The Following User Says Thank You to GQtdauto For This Useful Post:
    dom14 (19th November 2017)
  7. #15
    38 Post(s)
    I've gota a find a way to source alternative cheaper ways to get hold of some CO2 canisters.
    Cheetah Outreach
  8. The Following User Says Thank You to dom14 For This Useful Post:
    GQtdauto (19th November 2017)
  9. #16
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Also worth considering because you're a cheap bugger like me , see if you can get some helium , like what you use in party balloons , no idea how it would work in a mig but it was the first gas they used in Tig welding when it was invented many moons ago .
    It is possible to use Co2 in a Tig for low carbon steel but Co2 is reactive so you will burn out your tungsten electrode in quick order .
    When mig welding with flux cored wire and using Co2 the above is not an issue because your continually feeding the wire through and consuming it .
  10. The Following User Says Thank You to GQtdauto For This Useful Post:
  11. #17
    38 Post(s)
    I most certainly can get helium but won't be any cheaper though.
    Party suppliers have it but too dear to make it useful on MIG or TIG.
    Argon is a by-product of some industrial process according to what I've heard and they are making a super fortune from it.
    As a cheap bugger I beat you to it, 'cos I just built a 'massive' cage out of scrap. , but I made it look cool, except the weld tacks which looks like I've threwn up curries on it after having too much booze. , but that's the 'best' I could do with a stick welder and cheap electrodes.
    I'm looking at all different types of welding as a long term serious hobby, so I gota source cheaparse ways to source the consumables, particularly the shielding gas.
    My real aim is to be a damn good AC TIG welder, but so far it's only talk as I haven't got all the gear ready yet.
    I gave up on the gasless MIG welder and was planning to turn it into a sheet metal cutter by attaching a gas hose to the nozzle from the compressor. Now, I won't do as it would be a good backup MIG welder if I learn to use it with a bit of parallel thinking, following your tips.
    Cheetah Outreach
  12. The Following User Says Thank You to dom14 For This Useful Post:
  13. #18
    Expert billyj's Avatar
    gordon
    biggest problem you will have is you need different gas mixes for different metals and processes
    is argon/co2 mix to mig steel, straight argon to mig aluminium or tig steel and from memory its an argon/helium mix for tig aluminium
    gone to the dark side 2017 vdj 79 dc
  14. The Following User Says Thank You to billyj For This Useful Post:
  15. #19
    Dec 2016
    Northeast Victoria
    41 Post(s)
    You can use argon for pretty much everything Tig but generally the mixes are formulated to tweak the welding performance
    As in the case of using an Argon /helium mix for aluminium gives a broader flatter weld profile and argon / Co2 gets a bit better bite on low carbon steel .
    From what I've read and experienced these properties are more desirable in mig welding because you have more control when Tig welding .
    Same as using the Ceriated tungsten electrodes in Tig , you can use the one type for pretty much all types of metal your likely to weld you only have to change the way you prepare the end of the electrode .
  16. The Following User Says Thank You to GQtdauto For This Useful Post:
  17. #20
    Patrol Guru paulyg's Avatar
    Ballarat
    Check Total tools, they also sell the gas bottles
    2010 TB4.8, 5 speed auto TI Wagon, Beaudesert ceramic coated Extractors and 2 1/2 inch exhaust, 3inch lift, BP-51 shocks, Black hawk radius arms and drop boxes, Road Runner Offroad billet alloy draglink, Boss air bags, 295/70/17 KM3s, Redarc Gauges, GME XRS UHF, Autometre fuel gauge, Alpine head unit with offroad maps, Carbon winch, Opposite lock bull bar, Light Force Strikers, Safari Snorkel, Duel long range tanks, work in progress.
  18. The Following User Says Thank You to paulyg For This Useful Post:
