Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Remap regrets
    Patrol Freak Bidja's Avatar
    Jul 2017
    Southern Table Lands, NSW
    40 Post(s)
    Quote Originally Posted by Rock Trol View Post
    I noticed more smoke after the remap but my exhaust point downward and to the rear instead of the side like oem exhaust. I also have a fridge in the back which is high up so can’t see that much. Taking off up hill though it leaves a big black cloud so have to be careful not to lug it. Much more than before the remap.
    Sounds like been too rich from 2014 remap then. Lot more knowledge out there now for doing ECU remaps. Your call, maybe a remap is a good option with correct tune.
    Did recent remap (crd) does no smoke what so ever that is visable (3.1T-not camped up), run well (postal remap $790 inc post).
  2. #12
    Mar 2013
    NE Melbourne
    UPDATE:
    I had the Patrol put on a dyno today and I am happy to say that the news on that front is very good.
    The lowest AFR was 18:1 during the runs which is quite lean. It also topped out at about 96 KW and around 370 NM at the wheels.
    They will email the dyno results to me tomorrow (their printer was not working) so will get all the results.
    This leaves the possibility that the injectors may be on the way out. They said it was not too bad at the moment though so will keep an eye on the smoke issue.
  3. The Following 5 Users Say Thank You to Rock Trol For This Useful Post:
    Avo (20th December 2017), Bidja (20th December 2017), Hodge (20th December 2017), jack (20th December 2017), threedogs (21st December 2017)
  4. #13
    Maybe all it needs is a good long run flat stick to clean it out a bit, a bit hard to do,
    maybe run some castrolT2 or injector cleaner through it next big trip,
  5. #14
    Mar 2013
    NE Melbourne
    The following are photos of the dyno run.
    First one shows the power (95.6kw) and torque (approx. 344nm).
    This shows the Air Fuel Ratio which pretty much stays between 18-20:1
  6. #15
    can someone tell me if the dealerships can tell if your ecu has been remapped..i was under the impression they couldnt tell but someone has suggested they can...
  7. #16
    Yes........
  8. The Following User Says Thank You to Clunk For This Useful Post:
    Avo (20th January 2018)
  9. #17
    Yes........
    dunno if you're full of shit or telling the truth
  10. #18
    Your guess is as good as mine
  11. The Following User Says Thank You to Clunk For This Useful Post:
  12. #19
    AFAIK they can if for some reason they need to look.
    For any factory updates all they do is just dump it into the ECU, no Dealer would be rrsed checking every vehicle thru the shop (not just Trols) so it would be every vehicle for non-factory remaps.
    Chips are a different story... and for the record.. to answer the other Q, my guess is Yes
  13. The Following User Says Thank You to the evil twin For This Useful Post:
  14. #20
    I run a DP chip happy as when turned up to 9 it billows black smoke ,so I dropped it back to 6 good power for towing no smoke.
    plus I can remove and put Patrol back to factory
