Page 800 of 1057 FirstFirst ... 798799800801802 ... LastLast
Results 7,991 to 8,000 of 10566
  1. #7991
    Ran and connected the wiring for the tank and filter heaters today. Marked out the position for the bonnet 'gills' to aid under bonnet cooling, and cut the bonnet supports away from the skin - doing the cut-outs tomorrow.
  2. #7992
    Bonnet gills installed, fiddly job, heart in mouth as I cut the holes in the bonnet though! Came up well. The fibreglass gills didn't come with any fixing bolts, so used araldite, with mixed success - can't take a tensile load so had a few break off. Ended up using a black SIKAFLEX product and the bolts in combination to pull it down to the bonnet profile. DSC01832.JPGDSC01833.JPG
    I will eventually get them colour matched when i get the rear section of the roof above the rear doors touched up from numerous dropping of stuff and chips formed.
  3. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    GQtdauto (29th September 2017), Rossco (29th September 2017)
  4. #7993
    22 Post(s)
    It would be interesting to see a string/tissue paper or whatever test to see which way the air flows through the vents
    96 GQ coil/Cab
    08 G6eT
  5. #7994
    Good idea, will do that for sure. I am working on the air flowing out from under the bonnet.
  6. #7995
    Nov 2010
    Getting a life...
    38 Post(s)
    Polished his bullbar.
    KATROL- The 2nd
    GU TD42TGi
    Silent member 1208
  7. The Following 6 Users Say Thank You to katwoman For This Useful Post:
    mudnut (29th September 2017), mudski (8th October 2017), PeeBee (29th September 2017), Rossco (29th September 2017), Stropp (29th September 2017), Yeti's Beast (30th September 2017)
  8. #7996
    22 Post(s)
    It will at slow speed definitely. I have installed these on a turbo tb42 and you can see the heat rising through at basically a stand still, but at speed it is high pressure at the base of the windscreen, and forward of the cowl. What I would like to know at say 100kmh which way air is travelling.
    96 GQ coil/Cab
    08 G6eT
  9. #7997
    OK, took a piece of fine string and stuck it to the bonnet. Went for a spin and totally baffled.
    0-15K/HR no movement
    16- 100K/HR, the string pivots around and faces the direction of travel up to about 95, then it starts to flap from side to side - drivers to passenger side. The string sits flat on the bonnet. the location of the string was varied from centre of bonnet to in front of the new GILLS, and then on the GILLS, exactly the same effect.
    At idle, I can feel a gentle airflow coming out of the GILLs, but not enough velocity to move the string.
    So I have achieved what i wanted that being a low speed escape path for the heat, but now curious to understand the airflow which is contrary to what i would have thought - I was expecting a flow in the direction of the windscreen - doesn't happen.
    Any ideas????
  10. #7998
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    If the only way airflow could escape from the engine is through the vents it would but I'm sure most of it if not all escapes through the bottom of the engine because it's the easiest path of travel for it .
  11. #7999
    Agree???????
  13. #8000
    22 Post(s)
    Any ideas????
    I would redo that test using multiple pieces of string all over the bonnet, and around the vents, that way you will get a solid indication of is actually happening over the majority or all of the bonnet.
    I really know bugger all on the subject, but the string flapping side to side, to me says turbulence and lots of it?
    96 GQ coil/Cab
    08 G6eT
  14. The Following User Says Thank You to Ben-e-boy For This Useful Post:
    PeeBee (30th September 2017)
