Page 792 of 1057 FirstFirst ... 790791792793794 ... LastLast
Results 7,911 to 7,920 of 10566
  1. #7911
    Did you find it?
    yep....she just need a better bra
  2. The Following User Says Thank You to Avo For This Useful Post:
    Stropp (3rd September 2017)
  3. #7912
    Finally got the fuel consumption flow meters installed and working, however the double Dutch Romanian inverse instructions for setup are doing my head in. Trying to set it up for lph instead of ppm isn't playing the game and struggling to set the parameters so the flowratezeros each time the engine stops. More time on the phone tomorrow with the agent to try and resolve.
    Also made a couple of stainless steel storage drawers for tools and recovery gear that go under the existing rear storage setup, will post pics when it's finished. This should take a heap of stuff from the back seat
  4. The Following 3 Users Say Thank You to PeeBee For This Useful Post:
    GQtdauto (9th September 2017), MB (8th September 2017), mudnut (7th September 2017)
  5. #7913
    Advanced morton2478's Avatar
    Mar 2015
    Today was day 1 of converting the 3ltr to a 4.2 happy days
    Sent from my SM-T530 using Tapatalk
  6. The Following 6 Users Say Thank You to morton2478 For This Useful Post:
    AB (8th September 2017), Avo (8th September 2017), GQtdauto (9th September 2017), Hodge (9th September 2017), MB (8th September 2017), Rossco (9th September 2017)
  7. #7914
    Are you starting a build thread mate?
  8. #7915
    177 Post(s)
    Fitted up the infinity fan to the motor.
  9. The Following 3 Users Say Thank You to Hodge For This Useful Post:
    GQtdauto (9th September 2017), gubigfish (9th September 2017), Stropp (10th September 2017)
  10. #7916
    Aug 2014
    Perth
    10 Post(s)
    Be interested to know how much that affects the cooling @Hodge approx how much for the fan?
  11. #7917
    177 Post(s)
    Quote Originally Posted by gubigfish View Post
    Will be interesting to see too mate. Most people who have it, have said it performs better. Can instantly tell it pushes air more and you can actually hear the whir of the fan, much more noticeable than the original. My motor doesn't overheat, nor do I tow or push it too much so, I don't know how it will perform at mostly idling temps, compared to say somebody whos got it fitted and does a lot of towing and the temps are on the higher scale.
    It cost me around $120AUD shipped from UAE. Thats using https://partsouq.com/ which nissannewby put me onto. Ive bought a few parts from there and saved a ton compared to anywhere local and shipping is fairly fast too.
  12. The Following User Says Thank You to Hodge For This Useful Post:
    MudRunnerTD (24th September 2017)
  13. #7918
    I found pretty much zero difference just running the fan of a stock, unmolested fan clutch. only when I added more oil in the hub I saw any cooling change. But a better fan to have none the less.
  14. #7919
    Patrol God Stropp's Avatar
    38 Post(s)
    Yes I paid $450 with the bigger hub and fan from ufi made a lot of difference, you can actually hear it.
  15. The Following 2 Users Say Thank You to Stropp For This Useful Post:
    gubigfish (10th September 2017), Hodge (10th September 2017)
  16. #7920
    Finished the majority of the rear setup today, just a door to make tomorrow.
    Swapped out the HID headlights for LED Globes, running thru a Piranha headlight loom. Keen to see the difference, globes only, not the headlights - when they tone down the design to stop them being easily recognisable i will probably swap over to them.
  17. The Following User Says Thank You to PeeBee For This Useful Post:
    MB (10th September 2017)
