Only real problem with the supercentre is if you have a problem trying to contact them , their customer service is second only to Telstra .
Yes the do have some crappy stuff but if you read the various forums or google problems with the product you want you can at least decide wether or not to go cheap or big brand , their Draws are a good example , loose bolts etc just means checking them all before installing and the side wings for the GQ wouldn't clip in .
Just a case of undoing two screws and moving the clips about 10mm towards the back , seen many that cracked the shits and sent draws back over this problem but so easy to fix .
The first side awning I had from them was a bit shit but the latest bigger one is much better in construction and easier to setup .
The double thumper air compressor for the price is streets ahead of any competitor .
Saving a few bucks here gives you more spend for importatant stuff .
