Page 408 of 570 FirstFirst ... 406407408409410 ... LastLast
Results 4,071 to 4,080 of 5698
  1. #4071
    Expert Mike02Ti's Avatar
    Jun 2016
    Rockingham WA
    4 Post(s)
    @Hodge yep used to get them like that all the time. Near on single warranty claim we had was because of low or no oil. Take it back and they will fill it for you if you want
    2002 GUIII Ti 4.8
    Details here
  2. The Following 2 Users Say Thank You to Mike02Ti For This Useful Post:
    Hodge (30th August 2017), Yeti's Beast (30th August 2017)
  3. #4072
    177 Post(s)
    Quote Originally Posted by Mike02Ti View Post
    Do you know if it takes ordinary hydraulic oil? Because i've got access to Mega-litres of it.
    Jun 2016
    Rockingham WA
    4 Post(s)
    Yeah normal hydraulic oil mate. Used to keep a drum out the back of the shop for that brand of jack alone. Other than that they worked alright. I have still got one in the shed somewhere.
    2002 GUIII Ti 4.8
    Details here
  5. The Following 2 Users Say Thank You to Mike02Ti For This Useful Post:
    GQtdauto (30th August 2017), Hodge (30th August 2017)
  6. #4074
    150X150mm,90W@12V. w/ 3M PSA & Sponge, Keenovo Universal Silicone Heater Pad/Mat
    2 off 12V 90W heater pads for both fuel tanks, got them on ebay, of course.
  7. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    MB (30th August 2017), Rossco (30th August 2017)
  8. #4075
    Should the trick . . .
  9. The Following User Says Thank You to Rossco For This Useful Post:
    PeeBee (30th August 2017)
  10. #4076
    Fark the fuel tanks. Chuck'em under your sleeping bag.
  11. The Following 2 Users Say Thank You to mudski For This Useful Post:
    GQtdauto (30th August 2017), PeeBee (30th August 2017)
  12. #4077
    Patrol Guru Sprock's Avatar
    Jun 2015
    Heyfield Vic
    35 Post(s)
    Mate you were spot on. Either it's not topped up fully or theres none in there. Says it's meant to be 5mm above inner cylinder, in the photo you can see the inner cylinder with no sign of oil above or around it. That's really poor form I reckon.
    Pardon my ignorance but do you check it right up or fully down ?
  13. #4078
    177 Post(s)
    Fully down. Little tag that came with it says oil should be 5mm above inner piston in fully retracted position and valve open all the way .
    Dec 2015
    WA
    5 Post(s)
    I thought you needed to buy special Jack Oil, even if it is just for the name.
  15. #4080
    177 Post(s)
    I spoke to my hydraulic diesel mechanic before and he says many of those jacks come with no oil depending on how they arrive from China. It's a maritime environmental Law some of them can't be shipped filled with oil and have to be filled in Aus instead. Or something along those lines .
    Is this the reason you think?
