Page 193 of 220 FirstFirst ... 191192193194195 ... LastLast
Results 1,921 to 1,930 of 2192
Thread: AB's new GQ is finally here
  1. #1921
    It sounded great as you left
    AB (27th February 2017)
  3. #1922
    We have just put a 3.5" exhaust on the one I am doing up here. Sounds real nice.
  4. The Following 2 Users Say Thank You to nissannewby For This Useful Post:
    AB (28th February 2017), MudRunnerTD (27th February 2017)
  5. #1923
    Finally had a couple of hours kid free!!
    Replaced the 4" inlet with a nice wanker shiny alum one!
    Also installed the line for the td42t vacuum to a T on the alternator Vac line, dual Vac!!!
    Brakes are a lot better now!
    Would it be worth getting a bigger canister now?
  6. The Following 2 Users Say Thank You to AB For This Useful Post:
    gubigfish (2nd July 2017), MB (2nd July 2017)
  7. #1924
    Ooh shiny. . Yeah nice cool mod. Yeah don't know if bigger can would be good or not probly help in those long idling crazy down hills but with double vac might not need it. . Better go testing.
  8. #1925
    We were way off too. The line tucks right up under the sump mounting to the timing case and block as below.
  9. The Following User Says Thank You to AB For This Useful Post:
    Rossco (2nd July 2017)
  10. #1926
    Oh wow, yeah that looks heaps better. I wonder if that sound deadening mat on the sump does much, might try it out one day if i have any leftovers. .
  11. The Following User Says Thank You to Rossco For This Useful Post:
    AB (2nd July 2017)
  12. #1927
    I was thinking why we didn't spot those vac line mounts on your silver top and then thought maybe you don't even have it as that wasn't needed back then of course.
  13. #1928
    Soooo we just did the snow trip and as some of you know my intercooler has been leaking and I've gradually being losing boost and power
    Can't believe the good members on that trip here haven't bagged me out yet, bloody good blokes!!!
    So I'm sitting in my Gq in thick snow, Saturday morning cold as F ready to do a day trip of tracks.
    Trying to reach operating temp so pull the idle out and nothing happens????
    Annnnd it turns out my IC and piping is 100% fine!!!
    At that moment I pulled the idle screw out and no response it clicked I have an issue with my throttle cable!!!
    Low and behold the bloody nuts have been slowly working loose over the last month...lol
    I blame Matty really, totally his fault for not asking me to check if the bloody throttle control on the injector pump has been slowly winding out over time!
    So Matty vic asks for a 10mm, then a 12mm, then a 13mm in which we thought 13? And then finally a 14mm spanner, 23 seconds later my beast is back, better than ever!!!
    Embarrassment!!
  14. The Following 5 Users Say Thank You to AB For This Useful Post:
    BigRAWesty (27th August 2017), GQtdauto (25th August 2017), Rossco (26th August 2017), TPC (25th August 2017), Winnie (25th August 2017)
  15. #1929
    Quote Originally Posted by ab View Post
    soooo we just did the snow trip and as some of you know my intercooler has been leaking and i've gradually being losing boost and power
    can't believe the good members on that trip here haven't bagged me out yet, bloody good blokes!!!
    So i'm sitting in my gq in thick snow, saturday morning cold as f ready to do a day trip of tracks.
    Annnnd it turns out my ic and piping is 100% fine!!!
    At that moment i pulled the idle screw out and no response it clicked i have an issue with my throttle cable!!!
    i blame matty really, totally his fault for not asking me to check if the bloody throttle control on the injector pump has been slowly winding out over time!
    So matty vic asks for a 10mm, then a 12mm, then a 13mm in which we thought 13? And then finally a 14mm spanner, 23 seconds later my beast is back, better than ever!!!
    Embarrassment!!
    Sent from my iphone using tapatalk
    D i c k H e a d ! ! ! !
  16. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    AB (25th August 2017)
  17. #1930
    Classic ! ! Matty to the rescue again
  18. The Following User Says Thank You to Rossco For This Useful Post:
