Is that so you can put the windows up AFTER you've turned the key off ?
Yes.... But this doesn't work on the drivers window as its not control by the relay.
http://www.ebay.com.au/itm/GU-Nissan...-/122374891586
That's 1 thing that pisses me off with the Patrol , turn key off& notice a window down so have to turn key back on etc , seems petty but it's a nuisance- I can take the keys out of the Commodore & close the door & still be able to just open the door & hit the window button .
Wonder why just that window isn't controlled through the relay ?
Yeah our Bommodore is the same. I reckon there one more thing that would piss me off about your Patrol too! Haha!
Absolutely no idea as to why this is the case.
I reckon I can by pass it via the window switch and then it has power all the time.
Talking of electric windows, I had a look at a DX ute with a 4.2 diesel motor and noticed there`s no window winder on the drivers side door, but there`s one on the passenger side door. Found out the bloke who owned it, put in a electric winder in hooked up to a toggle switch. Had to laugh.
Took the Pootrol out this arvo to blow the cobwebs out of it, I had a strange noise coming from underneath, I look and found I have a broken exhaust bracket, the one above the rear diff, and also the bracket that bolts to the transmission is near cracked right through. I finally ticked about 6 things off the "to do" list this week and just added two back on.
BigRAWesty (27th August 2017), Bush Ranger (25th August 2017), Hodge (25th August 2017), MB (25th August 2017)
^^^ One step forward, two steps back.
Aaaand I've just added more on to the list.
So I bought a new driver seat cushion yonks ago as mines stuffed. I finished work this arvo early enough so I thought I'd get the seat out of the Patrol and apart. Yep the cushion is rooted as I thought....
...but I found more. Hope my mig welding skills are up to scratch.
GQtdauto (29th August 2017), katwoman (29th August 2017), my third 256 (3rd September 2017), Stropp (29th August 2017)
