Results 31 to 40 of 40
Thread: My GQ manual torque converter lock up system (lotts of photos)
  1. #31
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Quote Originally Posted by nuts1957 View Post
    #Question can i do this with the now td4.2t having different TC to the tb4.2 i believe the trans is the same
    There is a member on here that done it to his GU Nissan Patrol 3.0Di using the Jatco RE4R03A Transmission, so can't see why not on the 4.2
    Where is a link to his website: http://www.chaz.yellowfoot.org/Locku...s%20Switch.htm
    Ask the question in its own thread and hopefully he will see it
    Toddie
  2. The Following User Says Thank You to NissanGQ4.2 For This Useful Post:
    nuts1957 (14th July 2013)
  3. #32
    Mar 2013
    South East Qld
    Thank you, checked it out and it seens the transmission is the same but the TCU is a little different poto attached as said factory TD4.2 Auto cant add pic but control unit is NTC 57
  4. #33
    Expert ripper's Avatar
    Leeton NSW
    Hopefully you can find a service manual which covers your TCU. It will probably do the same thing with the torque converter, but may use a different coloured wire to do it. We have a couple of Canadian members here who may be able to help you, as I think they have Nissan "Safari"s which used autos behind diesel engines sometimes.
    1989 GQ LWB Wagon, TB42 Petrol/LPG Auto. Bought Dec 2010
  5. #34
    Patrol Guru Chubba's Avatar
    Oct 2013
    Adelaide
    5 Post(s)
    When I joined this forum this thread is exactly the kind of thing I was hoping for. Detailed step by step photo filled instructions on DIY jobs. Well done ripper excellent work. I can't praise your efforts enough.
    WHAT A RIPPER!
    98' Ti, 4.5L, 2" lift, factory rear diff lock with front E-locker, 63% reduction gears
    "GO YOU CROWS"
  6. The Following 2 Users Say Thank You to Chubba For This Useful Post:
    ripper (7th January 2017), rusty_nail (15th September 2015)
  7. #35
    Leeton NSW
    Thanks Chubba and you're welcome. Others here have helped me heaps, so this is just passing it on.
    Sorry I missed your reply here way back when you posted it.
  8. #36
    Jul 2017
    Wesburn vic
    Hi ripper can you tell me where the torque converter lock up solenoid is located so I can have ago at installing your system. Thanks Benrosti
  9. #37
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Quote Originally Posted by Benrosti View Post
    Not sure myself but assume the solenoid is in the box itself , you don't need access to it just the wire coming from the tcu which is in the front passenger side kick panel .
  10. #38
    Jul 2017
    Wesburn vic
    Thanks for that. I mainly want this mod for steep low first driving. Do you know if it will work on a GQ with out replacing the valve body it seems that some say yes some say no
  11. #39
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Reading what ripper has posted it seems that our GQs won't lock up in first gear only 2 and up unless you upgrade the valve body .
    Ripper would be able to confirm but I don't think he's a regular user of the forum .
  12. The Following User Says Thank You to GQtdauto For This Useful Post:
    Benrosti (30th July 2017)
  13. #40
    Jul 2017
    Wesburn vic
    Ok thanks patrol freak Looks like I need the up grade on the valve body too
