Should not be a problem hooking up 3 lights to the same relay as long as the relay & wiring can handle the amps. Would suggest a 40 amp relay & 15 amp wiring to each light from the relay. Each light will draw around 8.3 amps (watts(100) divided by volts(12) = amps). The wire from the relay to the switch does not have to be as heavy as it only supplies switching power to the relay.
You would need at least a 30 amp wire & fuse from the battery to the relay as the lights would be drawing 25 amps in total.
