Results 1 to 10 of 10
Thread: odd suspension rake
Threaded View
  1. #6
    Legendary happygu's Avatar
    There are only a few things that will make the spring height different
    1/ Mismatched or Heavy Duty / Longer oils ( Longer Coils for a higher lift ) Coils are available in 2, 3, 4, 5, 6 inch lift,etc, etc or ( Heavier Spring Rate Coils ) to carry extra weight
    2/ AirBags within the rear coils
    3/ Air Assisted Shock Absorbers, although I haven't seen these for a while
    To me it doesn't look too bad at all, but I don't like bum draggers, and would prefer the rear to look like it sits higher normally, as when you load it up the rear will tend to drop with the extra weight anyway.
    The other thing is, it looks like you may have standard size tyres and rims, and a suspension lift without 33"tyres to fill the space sometimes makes it look a little odd.
  2. The Following User Says Thank You to happygu For This Useful Post:
    GQtdauto (16th July 2017)
