Page 24 of 64 FirstFirst ... 2223242526 ... LastLast
Results 231 to 240 of 635
Thread: Rosscos GQ Rejuvenation
  1. #231
    That sound deadening though!!! OMG! Slick Rossco.
    Hey a 70mm foam Roller is your friend Next Time you paint the chassis. What prep did you do to the chassis and what paint?
    Rossco (10th July 2017)
  3. #232
    Legendary happygu's Avatar
    [QUOTE=Rossco;733108]Yeah still not the one I remember, cheers anyway craig. Had a bit of a dig might have more of a look later. . .
    Anyways finished painting chassis with brush, looks pretty smick.
    A bit better cleaned out, should save a bit of weight. Put in some 15mm coil spacers all round too, so with the reduced body lift should be similar to what it was.
    That just looks sexy as ..... unfortunately, it won't take long till it will never look this good again I reckon ....
  4. The Following User Says Thank You to happygu For This Useful Post:
  5. #233
    [QUOTE=happygu;733153]
    Ahhh but you don't know our Rossco! He will be out there with a toothbrush giving it a good scrub after every trip.
  6. The Following 2 Users Say Thank You to Winnie For This Useful Post:
    Maxhead (10th July 2017), Rossco (10th July 2017)
  7. #234
    Yeah i know it's smick as.
    Yeah roller's a good idea actually I'll definatly keep it in mind next time i paint the chassis. might make it a monthly routine. . .
    Just Karchered it, wire brushed bad bits and used prep wash with a rag everywhere i could get to. Just used motospray chassis black from super dodgey . . . Should see the rear diff too OMG it's to die for . . Just need to do the front one, plan was to put in the diff brace while the body was off but ran out of time, that's next on the list. .
  8. The Following 2 Users Say Thank You to Rossco For This Useful Post:
    Family4x4 (8th May 2020), MudRunnerTD (10th July 2017)
  9. #235
    SUCH IS LIFE Maxhead's Avatar
    ACT
    That's some impressive work there Rossco....very inspirational...pity I wouldn't have the patience to do something like this.
    I thought wiring my little led bar was bad enough...lol
    ................on the road
    ________________________
    ______ 2017 D-Max _______
  10. The Following User Says Thank You to Maxhead For This Useful Post:
    growler2058 (11th July 2017)
  11. #236
    You'd be right Krisso, few glasses of moonshine and just tinker away. . .
  12. The Following 4 Users Say Thank You to Rossco For This Useful Post:
    GQtdauto (10th July 2017), Maxhead (10th July 2017), mudski (10th July 2017), Winnie (10th July 2017)
  13. #237
    What your sort matting have you used on the floor of the cab there Rossco?
  14. #238
    Ping Jing, seems pretty good, is cheaper than dynamat and a bit thicker i think. Pulled the factory stuff out of the firewall if the old one, is a little ratty in bits but think it's salvageable. . .
  15. The Following User Says Thank You to Rossco For This Useful Post:
  16. #239
    Patrol Guru Sprock's Avatar
    Jun 2015
    Heyfield Vic
    35 Post(s)
    Hahaha monthly painting of the chassis 😝 , I'm about to strip my 'BIG' truck seats & floor out & line it all with dynamat but I'd heard of PingJing & now I've seen you've used it I might give it a go .
  17. The Following User Says Thank You to Sprock For This Useful Post:
    Rossco (11th July 2017)
  18. #240
    Finished the front diff yesterday, was a bit of a mission doing everything lying down upside down!
    Laminated & braced using race bred kit, good stuff as always from them.
    Also comes with gussets for the steering knuckles. Hope I didn't get to much heat into the axle seals and it starts leaking. Find out I guess. . .
    Starting to look a little bit more like a car slowly . . .
  19. The Following 5 Users Say Thank You to Rossco For This Useful Post:
    Avo (19th July 2017), Bacho86 (12th July 2017), GQtdauto (12th July 2017), growler2058 (13th July 2017), mudski (12th July 2017)
