Results 1 to 10 of 19
Thread: TB42 & TB45 Fuel Economy
Threaded View
  1. #18
    Expert billyj's Avatar
    gordon
    before you go buying a new carbie, go get a dyno shop to do a couple of power runs then they can actually see what the afrs are doing in real time under load.
    an afr gauge is only half the battle to getting a tune right while 14.7:1 may be stoich and ideal at cruise you will be loosing power under load as best power is made at about 11-13:1 so if everything is working right you should be running rich under wot then lean off when at cruise. if your only at 14.7:1 under load then your at a much higher risk of pinging and proobly running less timing than ideal to compensate. the point being that if your down on power your going to be using full throttle or more throttle more often trying to pick up and maintain speed
    11351133_10153391028716133_6811608451076355849_n.jpg this is the 355 holden stroker i hand built for my old vs ute made about 240kw with a cam suited to low end torque
    gone to the dark side 2017 vdj 79 dc
  2. The Following User Says Thank You to billyj For This Useful Post:
    dom14 (5th July 2017)
