There are a few possibilities .....
Make sure that your truck is parked on a flat level surface to check spring heights, as just having the back wheel in a hole or hump will affect the front height on the opposite corner.
Cheapest Option..... if everything seems ok, and there are no problems driving around just leave it as is.
Next Cheapest Option .... If you can get a similar one from a wreckers, you could replace it with a second hand unit, but you need to know if it is standard or lifted.
Next Cheapest Option .... You can get your spring reset, and that would involve taking the spring out for reshaping
Then lastly, you would install a brand new spring, although I would probably never do just one so that adds to the cost.
