Quote Originally Posted by KIWIBOB View Post
Hi GQtdauto, You can buy a seal kit and replace the 'o' ring on the mixture adjusting screw and the gasket on the top lid. If that dosn't fix the leak, the pump will need to be taken out and sent to a specialist. Hope my thoughts help. Regards Kiwibob.
It's the top lid o ring that's gone , I do have a complete seal kit and reckon I can do the top three it's just a bit of work removing the intake manifold so I can get at the flat screws etc , but if replacing all gasket/ o rings is a specialist job only maybe I better go that way .
I found some info and photos etc but can't find a parts diagram so won't attempt it unless positive I can do it without stuffing it up .
