Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Error lights came up on dash, TC, ABS, Stab Cont, Diff Lock with 3 bells
    Jul 2014
    Thanks for your help Yendor, the problem came back on the weekend so I used your fault finding factory diff lock problems thread to work through what was happening. I moved the vacuum lines to direct vacuum and managed to get the diff lock to lock and unlock this way. There was no vacuum at either the lock or unlock from the solenoid so traced it back from there. Long story short, found the vacuum line that runs to the black plastic canister (assume it's a vacuum reservoir) has a one way non return valve in it and likes to be installed the right way round.. Who knew there was a valve in the rubber hose, a quick suck test either way found the problem.
    I suspect the gears in the diff were starting to engage without the unlock vacuum from the solenoid present and that was cause of my troubles. Ready for the Kimberley now :-)
    Thanks guys !
    Glad to hear you got it sorted.
    Just double check the two vacuum lines for the rear diff lock near where you mounted the charger. The lines run from the solenoid mounted on the top of the firewall (near the passenger side bonnet hinge) and run down beside the ABS pump. Make sure they are both still connected and the hose hasn’t split.
  2. The Following 2 Users Say Thank You to rob107672 For This Useful Post:
    Cuppa (13th June 2017), Yendor (13th June 2017)
  3. #12
    176 Post(s)
    Good feedback Rob. We all learn from each others woes this way.
