Results 1 to 7 of 7
Thread: redarc guages
    Feb 2017
    East Maitland NSW
    redarc guages
    Greetings are redarc gauges worth the money ?
    Im looking at oil temp & pressure & egt
    Any input would be great
    Expert Boinzo's Avatar
    Dec 2015
    Brisbane
    I have a Redarc dual battery volt-meter. It's a very well-made product, but the "needles" are so fine that I can't see them without putting my face right in it... it's down near the shifter so that's a tad dangerous on the move...
    You will need their illumination kit thing as well.
    2015 GU ST 3.0CRD Auto Wagon, 2" EFS Lift, 5 x Procomp 16s with MT ATZ P3s, TJM Outback Bar and 12000lb Winch, 80l Sub Tank, Redarc 40A DC-DC with Optima Battery and 180w Solar, ARB Compressor On-board, 3" EXHAUST, Rhino Pioneer Platform and Darche Awning, DIY Drawers to come!
  3. The Following User Says Thank You to Boinzo For This Useful Post:
    Rob Poynter (4th June 2017)
    IMO a lot happening in less than 52" gauge, lost of options
    Overpriced imo a nice set of VDO would do the same thing and easier ti read
    I use Speco and had no problems in 8 years so have
    Rob Poynter (5th June 2017)
    178 Post(s)
    I’ve got two in a pillar pod. EGT+boost, & oil pressure + coolant temp. Could’ve got 3 in 1 gauges but thought it may be a bit too ‘busy’. Love’em. Not cheap but good gear that I trust.
  7. The Following User Says Thank You to Cuppa For This Useful Post:
  8. #5
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    Same EGT + Boost, and Coolant temp and transmission temp. Being an auto and towing I thought it a good idea. I agree with the good gear...trust comment.
  9. The Following User Says Thank You to 4bye4 For This Useful Post:
  10. #6
    Expert Warwick89's Avatar
    Oct 2013
    Cairns
    So over priced!!!! BUT, i love them and would get more.
    2010 GU7, ZD30 CRD. ARB: bulbar, scrubbars, rock sliders, roofrack, front and rear air lockers, twin compressor. OME 2" lift, mickey T's ATZ P3 33" tyres x 6, opposite lock rear twin spare rear bar, Wurton 46" light bar roof mounted, draw system, clearview mirrors, redarc gauges: boost, EGt, engine pressure and temp, trans temp, battery. Dual battery system, 12,000lb warn winch, DYI sound/heat proofing.
  11. The Following User Says Thank You to Warwick89 For This Useful Post:
  12. #7
    Adventurist stevemc181's Avatar
    Jan 2017
    Thornlie,Perth WA
    8 Post(s)
    Yep, I love the redarc also, expensive but great quality. I only have one guage at the moment, EGT and Boost in a dual pillar pod. I also think the 3 in 1 gauge is too cluttered and prefer a bigger sweep on the needle as in the dual gauge. The enhanced lighting controller is certainly worth getting and one controller is all you need for multiple gauges.
    2016 GU Legend Edition: 3505Kg GVM Upgrade and Stuff!
  13. The Following User Says Thank You to stevemc181 For This Useful Post:
