Quote Originally Posted by Guyph_01 View Post
Good point. Thx for the pic but mine still has the std exhaust system on it. Anyone know if i still need to weld on a fitting or can tap into it somewhere?
You can drill and wld in a thread, or buy a new dump pipe pre drilled with a cap in it. you need to take the heat cover off the exhaust to see what is under it. I gor a new dump pipe and set it up then just changed over. Redarc also make a clamp thingingy but not sure about the resukts of that.
