Results 11 to 20 of 31
Thread: 2003 GU Patrol 3L Losing Power
    Mar 2017
    you could have a leakying intercooler ,,,is it oily if yes and will need to be changed to
    fully tigged and testetd one Diesel smart to a good 0ne dont go cross country for you
    3ltr just a waste of monet IMO, Money could be well spent elsewhere like a front lokker maybe
    There is a bit of oil down the side of the engine, around the turbo. I think its coming from the oil switch.
    The mechanic replaced the switch recently so i'm gonna get him to see whats happening there.
    There also seems to be a bit of oil coming out of the catch can hoses.
    I'm not really sure if or how that could affect the engine.
    I don't see any oil or leaks from the intercooler, but i will definitely get the mechanic to have a look.
  2. #12
    Mar 2017
    Quote Originally Posted by JackCollo View Post
    It's sounds it could be going into limp mode. With your Dawes valve set to 15 psi it could have just slipped over into lump mode. Did any lights on the dash board come on or not
    Any change in fuel economy?
    What is limp mode? Does it signify something bad?
    No lights on the dash at all.
  3. #13
    SkippyGU JackCollo's Avatar
    Dec 2016
    Melbourne VIC for now
    Quote Originally Posted by lmath56 View Post
    There was plenty of fuel in the car every time it happened.
    I replaced the air filter today and found that the old was really dirty,
    I went for a 5 hr drive tonight and it is definitely still happening.
    I was pulling a small trailer with nothing in it and it usually drove fine, but sometimes it decided that it wasn't going to go faster than 90 and the exhaust temp started to go up.
    I didn't let it get over 400 degrees.
    what temp did it go from and to. how quickly did it go up?
    so the temp shot up when it lost power??
    starting to sound like a dirty MAF duck down to supercheap grab a can of mass airflow sensor cleaner. pull the maff off and the pipe that goes from the top of the airbox that the maf is apart of and give a darn good spray down from as many angle.
    cheers
    Currently own a ZD30 2000 GU patrol with a dead injector pump about to start a build on a TD42 motor to go in the car and basically rebuild the whole car into a machine of a rig
  4. The Following User Says Thank You to JackCollo For This Useful Post:
    lmath56 (21st May 2017)
  5. #14
    Dec 2016
    Alright so basically on your intercooler you have a pressure sensor which is set to 16psi so when the turbo spools up and creates pressure if it goes past 16psi it limits power which explains the sudden power loss. and the way to take the ecm out of limp mode you realease throttle and engage it again.
    it wont set off any lights
    So in summary limp mode is designed to stop the engine doing damage to itself in the form of over pressuring and blowing gaskets and such other. Ive noticed a lot of the earlier patrol if people keep their foot on the accelerator in limp mode the temps do go up but then drop after throttle released. temps go up due to slight over fueling
  6. The Following User Says Thank You to JackCollo For This Useful Post:
  7. #15
    Mar 2017
    cheers
    It didn't go up too fast, I didn't strain it.
    I got it to about 400 Max.
    Yes when it lost power it seemed to get a bit warmer than usual.
    I will definitely give the MAF a clean
    Sent from my ONE A2005 using Tapatalk
  8. #16
    Mar 2017
    Ah ok, so the Dawes setting may have changed a bit and it needs to be adjusted back to 15.
    I will change that and see what happens.
  9. #17
    Dec 2016
    Give the maf a clean and adjust your Dawes setting and you should be sweet
  10. The Following User Says Thank You to JackCollo For This Useful Post:
  11. #18
    Disconnect the battery then service the MAF sensor with spray from Super cheap Auto.
    re fit the MAF when its dry reconnect the start battery and see how you go.
    You can test the IC by first removing it tape up the ends with duct tape use a bike
    pipe and dip in a kiddies pool, Clean the inside with kero make sure its dry [hair dryer]
    before reinstalling
  12. The Following User Says Thank You to threedogs For This Useful Post:
  13. #19
    Dec 2016
    On a total side note thank you threedogs for answering a question I had on how to clean intercooler. I was gonna use diesel? Is this a bad idea to use diesel only thought it would be good because if any is left over it will get burnt anyway but was told by someone else to use petrol which I know is an even worse idea.
  14. The Following User Says Thank You to JackCollo For This Useful Post:
  15. #20
    Expert Daveyboyjunior's Avatar
    Feb 2015
    Dartmoor, England
    I always use brake cleaner.
    Swill that around for a bit and do that a couple of times.
    Dries, evaporates a lot quicker, but as TD said....anything you use has to be totally bone dry before putting the IC back on.
