Results 31 to 38 of 38
Thread: UHF radio
  1. #31
    .......... TPC's Avatar
    63 Post(s)
    turned it on without arial attached? that has been known to stuff some
    Will only be a problem if you transmit without the aerial connected or with a damaged aerial but would not likely cause the radio to not turn on after.
  2. #32
    Hardcore belzi82's Avatar
    Jul 2011
    Avo. Aerial has always been attached so I dont think so.
  3. #33
    sheesh w3as just thinkin thats all.i stuffed one of m,y first ones tyhis way..gme it did throw up an error code..ah well
  4. #34
    Jul 2011
    Sorry Avo.
    Thanks for helping, appreciate it!!
  5. #35
    Quote Originally Posted by belzi82 View Post
    was thinking it may have been removed when bar was pulled off
  6. #36
    Jul 2011
    Could have been Avo but I doubt the insurance company would use it but then you never know they can be dodgy!!
  7. #37
    Sorry Avo.
    alls good mate,
  8. #38
    Aug 2014
    Perth
    10 Post(s)
    Thanks TPC. I will have a go and see how I go. Is there any way to tell there is a break in the wire apart from visually. I guess by checking with the multimeter. I am assuming it would be easy to buy more wire from Jayco or a car shop if this is the case.
    Car parts shops and Jaycar will have the type of cable required, when you buy a UHF it comes with the required power cable
