Page 758 of 1057 FirstFirst ... 756757758759760 ... LastLast
Results 7,571 to 7,580 of 10566
  1. #7571
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Finished the frame for the camper annexe to car so won't need to carry shit loads of poles , tested it out and it works well enough for me but will only be used if it's raining .
  2. The Following 2 Users Say Thank You to GQtdauto For This Useful Post:
    MB (6th May 2017), PeeBee (5th May 2017)
  3. #7572
    Whats the configuration - does the frame stay there or slide out ?
  4. The Following User Says Thank You to PeeBee For This Useful Post:
    GQtdauto (5th May 2017)
  5. #7573
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Frame folds down as in photo but is bolted onto the roof rack , it is held by a grip belt and heavy duty occy strap .
    Once these are off the two arms pivot up and I put the spigot piece I made up in either end and pull down .
    The brace has holes each end and is just a gal adjustable pole with a hole each end .
    One end goes in the hook under the spigot the other end attaches to an eye fixed onto the solar panel holding frame , I just put a big screwdriver though this then adjust the tension I need to pull the canvas tight , may put a occy over the spigot to hold canvas if windy .
    I've worked out that GQ needs to be between 2.300 - 2.400 metres from camper side , but ideal is 2.300 ish , it's not that hard to do I have done a few trials and got it every time once I knew what distance works best .
    If you want I can take some better photos of the bolted ends and brace connection points .
  6. #7574
    I am still struggling with this ! Maybe when you have it rigged up take a photo for me pls so I can appreciate your design. thanks
  8. #7575
    177 Post(s)
    Just ripped out a vacuum solenoid cluster bracket. Wasn't doing anything any more and was taking up valuable under bonnet real estate .
  9. The Following 2 Users Say Thank You to Hodge For This Useful Post:
    BigRAWesty (6th May 2017), MB (6th May 2017)
  10. #7576
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Have some photos of when I first hooked it up and when I moved the GQ a bit further away they are not great but might be what you're after .
    Didn't take a photo from the other side unfortunately, but the next photo I get will be while we are away for 8 weeks although hoping the weather stays fine .
  11. The Following 2 Users Say Thank You to GQtdauto For This Useful Post:
  12. #7577
    Full length flat rack for our trip.
    Uses rhino rack feet, 6 off.
    5 cross bars 300mm apart and 4mm mesh.
    It is now black.
    Best bit. Cost nothung. All steel lying around from other jobs..
  13. The Following 4 Users Say Thank You to BigRAWesty For This Useful Post:
    GQtdauto (6th May 2017), gubigfish (6th May 2017), MB (6th May 2017), Touses (6th May 2017)
  14. #7578
    Dec 2016
    Northeast Victoria
    41 Post(s)
    It is now black.
    That's one clean shed mate .
  15. The Following User Says Thank You to GQtdauto For This Useful Post:
  16. #7579
    Bahaha.
    Yea sure lol..
    Imo a bigger shed youll just have more shoit lol..
  17. The Following User Says Thank You to BigRAWesty For This Useful Post:
  18. #7580
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Bahaha.
    Yea sure lol..
    I see we have similar storage and filing systems but it looks like you could eat off your floor , mine was clean and tidyish about 3 months ago .
