Page 756 of 1057 FirstFirst ... 754755756757758 ... LastLast
Results 7,551 to 7,560 of 10566
  1. #7551
    [QUOTE=GQtdauto;724495]Finally done with the Silverado mirror conversion to the GQ , have a small issue with the left side mirror sitting too far forward but I know how to fix it but have to remove it and that's a rainy day job .
    Blinkers work and the adjustment controls are fine .
    at least the pics are the right way around when you click them
  2. The Following User Says Thank You to threedogs For This Useful Post:
    Yeti's Beast (26th April 2017)
  3. #7552
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    That's because I held the iPad upside down when I took the photos TD .
  4. The Following User Says Thank You to GQtdauto For This Useful Post:
    threedogs (1st May 2017)
  5. #7553
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Finished the cradle for the jerry cans to be put on roof rack , included a sand flag holder the design of which is courtesy of threedogs .
    Mucking around with an idea for attaching the camper awning to the car , if it all works that's if , it will bolt onto the side of the roof rack and trying to do it so there are no bolts to worry about to erect it , hook on the bottom of apex is for a brace to hold it all steady which is adjustable .
  6. The Following 3 Users Say Thank You to GQtdauto For This Useful Post:
    MB (30th April 2017), PeeBee (30th April 2017), Rossco (30th April 2017)
  7. #7554
    177 Post(s)
    Finished the dual battery install... Yes it's back to the front due to a unforseen case of me fitting draws at the back...
    Managed to squeeze the Redarc and the battery neatly into the tray. I need to get some kind of heat shielding which I'd like to stick to the turbo/engine side of the battery tray.
    GQtdauto (30th April 2017)
  9. #7555
    Dec 2016
    Northeast Victoria
    41 Post(s)
    I've put the third battery in a battery box left side front against the cargo barrier , just cut some marine ply to jack it all up a bit so it clears the fridge slide , most of my electrics originate on this side of the drawers so it's not wasted space .
  10. The Following User Says Thank You to GQtdauto For This Useful Post:
    Hodge (30th April 2017)
  11. #7556
    Made the rear mount bracket for the pressure relief valve on the hydraulic pump, fitted the pump to relief valve hoses and insulated them, now ready for the final two hoses to be manufactured, took the advice of members here and went the 'repairable style' route, so getting closer to finishing this nightmare installation.SANY0013.JPGSANY0014.JPG
  12. #7557
    Patrol Freak garett's Avatar
    Jan 2015
    north
    21 Post(s)
    adjusted the handbrake.. it should work for awhile.
  13. The Following User Says Thank You to garett For This Useful Post:
    rusty_nail (3rd May 2017)
  14. #7558
    177 Post(s)
    Just stripped the factory steps to make room for the new side steps. Car now looks a few inches higher lol.
  15. The Following User Says Thank You to Hodge For This Useful Post:
    GQtdauto (3rd May 2017)
  16. #7559
    Dec 2016
    Northeast Victoria
    41 Post(s)
    That's one clean shiny looking patrol there Hodge , ever go 4wheel driving in it .
  17. #7560
    It will look even higher with a bit of sill damage!! Nice car mate
    Sent from my P2 using Tapatalk
