Results 1 to 8 of 8
Thread: Electronic boost controller td4q
    Beginner MAP8P's Avatar
    Dec 2016
    Hi all I have GQ TD42 with a kinugawa td05 18g running 24psi boost it goes fairly well but with the manual boost controller the wastegate suffers from boost creep. It has a 1.5 bar spring in the wastegate actuator and i can get 26psi with wastegate signal line disconnected but boost response is heaps better. So was thinking of an electronic boost controller for faster spool up. Just wondering what other people are running?
    Expert billyj's Avatar
    gordon
    doesnt matter what controller you use if your getting boost creep it means the wastegate cant bypass enough exhaust gases to control the boost level corectly
    gone to the dark side 2017 vdj 79 dc
    Dec 2016
    No what i mean is the wastegate is opening way before full boost is achieved hence the reason i need the wastegate to stay closed until nearly full boost to allow faster spool up and to hold 24psi better
    gordon
    put more preload on the actuator, if it doesnt have enough preload then the wastegate can open up a little and cause slow response
  5. #5
    Dec 2016
    I have the wastegate arm with about 10mm preload without the manual boost controller it only makes about 6 psi. So i might have to try one of there 2 bar springs in the actuator.
  6. #6
    Dec 2016
  7. #7
    gordon
    try a bit more preload, but it sounds like you need to get an actuator to suit your target boost level
  8. #8
    Dec 2016
    Changed the spring a lot better now
