PeeBee (14th April 2017)
MB (14th April 2017)
Will do Tuesday, thanks Phil. Just checked Marks Adaptors website and their kit doesn't seem to have it pictured or listed either.
I'm now learning/thinking its got something to do with the input shaft GM-Nissan extension and or their mentioned thrust bearing extension carrier.
Lot's of little extra bits in there too I never new existed.
http://www.marks4wd.com/mfk605cd.html
Do you know if Scotty uses Marks kits or they have their own inhouse adaptor setup mate? Cheers!
Don't know who's kit they use, but for something as significant as a lub point it should be highlighted. I am going to have a look at my docs now and will come back with anything of value.
MB (15th April 2017)
Nothing in BD docs about the grease nipple. I am going to call Greg on Tuesday about having then clearly define how to bleed the injection system, as I got a gulp of air when running off the aux. tank on a steep downhill section and the engine spluttered to a stop. It was a pretty stressful 10 minutes trying to reprime when the filter bowl is full, the hand pump hard and no bubbles anywhere, what next? If cracking an injector, which one or how many, and as you know the pump is in the 'valley' and 80 percent cover erred by the air cleaner. Got it going in the end by pumping and cranking at the same time but took 2 people, what is the system if there is just me?
Crack all the lines at the injector and crank until you see fuel coming from them. This can be done in 15-20sec goes until fuel is visible at all injectors. Then just tighten them all back up and it should start, maybe a little rough at first on the odd occasion but will clear itself.
As for the bellhousing adaptor grease point this shouldnot require much at all. 1 pump each 10k service will be heaps. Or piss it off and go a proper auto and never look back.
PeeBee (15th April 2017)
