kbchez
Hi all,
Thanks parksey, i have no vacum air leaks.
Its when starting when cold It starts like a diesil with a air leaky system.
The link to the old posting is very helpful. Because I have removed the lpg from the wagon. Now I need to find the earth relay. I have seen one next to all the other relays under the bonnet. Maybe this one has something to do with the problem.
Is there a none return valve, for the fuel, at the fuel pump. I think its at or in the fuel tank setup.
A real wiring diagram would be helpful. To trace the injector wiring to lpg relay setup.
