Results 1 to 10 of 10566
Threaded View
    Expert Patrol'n's Avatar
    Oct 2014
    WA
    Replaced my steering damper, new shiny one in place, so that's sorted 😀 Went for a test drive, and a bit of belt noise, not a squeal, more of a whine that has a pitch increase with revs. Charge rate dropped a bit, so I got home and checked the new belts, which seemed to have stretched a little. Tightened up the belts, charge rate now seems ok. Didn't whine before I replaced the belts, is there a chance a new belt needs to wear in a little and will quieten down? I hope so, the aircon belt sucked to get on, and it's in front if the alternator belt..... (Wetting down didn't help). Any ideas?
    93 GQ wagon, RB30, extractors, 2 inch tough dog lift, 5 spd, A/T KO2 32's, steel winch bar, rated recovery points, red arc dual battery set up, rhino roof racks, UHF etc etc. Slow and steady might not win the race but it gets me there eventually...
  2. The Following User Says Thank You to Patrol'n For This Useful Post:
    juzzs8 (13th April 2017)
