Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: Mud tyre circa 35" to fit on standard Nissan steel split rims
    @PBBIZ2 we must know each other as I was in tlccv for years.
    Good friend of tony Bryant and dave white. Think I remember stories of that trip.
    Anyway have you thought aout putting a body lift on the GQ ??
  2. #22
    No but will it help? I have never considered it to be honest, am unsure about legality, bearing in mind I have spent a small fortune getting thru the VASS process.
  3. #23
    483 Post(s)
    I believe in Vic we are allowed a total max of 75mm/under 3" total axle to guard lift from stock (happy to be corrected though). You've already got a 2" sus lift too I believe so maybe 1" body lift could over max it. 35's are definitely a no no unless engineered with Portals too I believe. I'd also imagine a 33" tyre would be your GQ max legal. I'm assuming stock GQ's of your vintage were 31" or maybe under like 30" so worth checking that too. Two tyre sizes up max I think?
  4. #24
    Oh dear, looks like more time in exile. Portals are a major shift in my thinking, but possible - not this year but by the time the 32's are knackered, for sure. I am open to weigh up anything to be honest and if it makes total sense, its on.
    You miht have to make room in one of your paddocks MB in case exile becomes Xmas Hills.
  5. #25
    483 Post(s)
    Happy to rob a b&nk together tonight Phil and camp out in exile together in front of:
    http://www.marks4wd.com/portal-axles.html
    PeeBee (27th March 2017)
  7. #26
    These really are the ducks guts I reckon and I have no need for them but have always wanted'em. Fitted they look like circa 24k with the replacement GU axle housings, hydro brake boost and engineers. Seems like an expensive way to legally run 35" tyres, but the GVM also goes thru the roof as well.
    Yes, gotta have.
    Level me out a spot big enough for the patrol pls, maybe big enough for 2?
    MB (28th March 2017)
