My shower needs a bit of pressure to actually activate it. They reckon about 10m of downhill gravity to turn the machine on, so you'll probably need the pump anyway
I've got this shower tent though too which is pretty awesome!
https://youtu.be/JpJ61GbqU9M
i had this trouble while away at Christmas. I bought a copy of your unit but heaps cheaper. it came with a Pump but i plumbed into my camper and found the pump in the camper was too low a pressure (i fitted a low pressure low flow for water conservation!). Fortunately Liftlid was there and we opened up the unit and had a fiddle. we where able to drop the feed pressure regulator down a little to make it work. Need to fiddle with the temp sensor on mine though as i had the setting wrong.
Im happy to bring my Hotty too so we can run 2 shower tents for the win. I would set it up at my camp anyway so it might as well go to the group. I bought a double adaptor to allow 2 feeds off a single gas bottle too so we can run 2 units side by side no trouble at all.
The Showers could really be set up using just tarps for walls as no roof is needed and just walls if you have anything there. I may have a 2 room ensuite tent in my shed that my dad put there that he never used, if i have it ill pack it in.
Naomi has to work Saturday morning and Monday so will travel up in the Hyundai.
