Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: Help with light bar wiring needed
    Quote Originally Posted by PBBIZ2 View Post
    Re HID Hi/Lo, I just got pinged for my HID Hi/Lo's - not legal in Vic - maybe you are already aware? Heaps better than any halogens I have found, but that is irrelevant in the eyes of the law - just a heads up. Now have to swap them back to the old lights.
    been meaning to change them as they have burnt the reflectors from being too hot
    Dont drive much at night. Ill probably change them very soon to a OE set up
    anyone running LED headlights and are they legal ??
  2. #22
    Advanced juzzs8's Avatar
    Gold Coast, QLD
    Hey fellas, just bought a 42' and 2 x 6's. Just wondering how you blokes mounted them. Looking at mounting to underside of roof rack also. 42' at front and the 6's at the back for setup lights ( also trying to work out how I could mount the 6's to spin 90* to side of car for setup also if have any ideas?
    Cheers!
    2010 GU7 3.0L CRD
  3. #23
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Go back one page and look at photos I posted , under roof rack at front is what I have done the two smaller ones replaced the big spotties that were restricting air flow to radiator but I also got rid of the oversize "Nissan" badge as well and notice the difference.
  4. The Following User Says Thank You to GQtdauto For This Useful Post:
    juzzs8 (9th March 2017)
  5. #24
    Gold Coast, QLD
    Sorry. Meant like mounting brackets etc. did you use pre existing holes in rack or make your own? I've seen some ppl just cable tie there bars on. Others got extended bits of flat steel to reach out to the mounting brackets on the bar
    2010 GU7 3.0L CRD
  6. #25
    Gold Coast, QLD
    Was just wondering what you fellas did.
    2010 GU7 3.0L CRD
  7. #26
    Dec 2016
    Northeast Victoria
    41 Post(s)
    I actually used the spare brackets that came with the cargo barrier I bought , just a bit of heavy flat with a right angle bend , it's bolted on using two bolts with nyloc nuts and one metal screw per bracket , that is it will be when I replace two screws with bolts .
    Vibration from corrugations is a killer on roof racks and accessories if not fixed down right .
  8. The Following User Says Thank You to GQtdauto For This Useful Post:
