Results 1 to 10 of 20
Thread: ARB Bullbar Fog Light switches
Threaded View
  1. #6
    Dec 2015
    WA
    5 Post(s)
    Im not sure how they should be fitted from factory or ARB but DRLs can be wired in via ignition so they're on when the car is on or via a switch.
    I thought that DRLs had to turn off when the headlights were on, so ignition to one side of the relay coil, other side of relay coil via a diode to headlight +ve, or x2 diodes for low & high beam +ve.
    Graham
  2. The Following User Says Thank You to GeeYou8 For This Useful Post:
    Winnie (12th February 2017)
