Results 1 to 3 of 3
Thread: Engine oil
    Expert Tonks's Avatar
    ACT
    Engine oil
    I have been using Caltex Delo 400 multigrade in my 4.2 TDi, but finding it hard to get.
    Any recommendations on another good oil.
    Cheers Tonks
    2004 GU111 4.2 TURBO WAGON, 2" OME SUSPENSION, 33" MTZ's, 3" BEAUDESERT EXHAUST, ARB ROOF RACK, ARB AWNING, BLACK WIDOW DRAW SYSTEM & CARGO BARRIER, DUAL BATTERIES, 12,000lb WINCH, GME UHF, LIGHT FORCE XGT SPOTTIES, BERRIMA DIESEL TUNE.
    177 Post(s)
    I've been using Delo as well mate. Last two services I used Magnatec 15w 40 because I found it hard to find Delo as well and to try something different.
    Magnatec works fine.
    Sent from S5
  3. The Following User Says Thank You to Hodge For This Useful Post:
    Tonks (5th February 2017)
    Expert Col.T's Avatar
    Nov 2010
    Seaview Dwns.S.A.
    G'day Tonks,
    would you believe, when you key in 'engine oil' in the search panel at the top of the page, you get reams of irrelevant stuff. Dunno how that could be,,,,,but.
    Try 'Caltex delo 400' and you'll get the start of a heap of threads.
    Suggest though you try the Caltex help desk No. on the last drum, or on the Caltex site and the helpful chap on the other end will give you the locallest supplier.
    Worked for me in tiny Adelaide. I've used it in 2 patrols over about 500K and remain happy.
    Good luck.
    Col.
  5. The Following User Says Thank You to Col.T For This Useful Post:
    Tonks (12th February 2017)
