hey guys ,just found a bucket seat out of a rd28t 98 gu wagon.Was wondering if it will bolt into my 99 gu ute???---both are dx i have a 1 and a half seat in the passenger side i wish to swap ---cheers chris
You don't drive...you patrol!
99 gu dx 4.2 diesel cab chassis - "THE GOLD DIGGER"
Im sure they will as the floor pans will be the same still
Boagie (27th April 2011)
Better than good chance they will but you may have to drill holes for the inside passenger seat runner (Not 100% on this) as its unlikely the holes for a bucket seat setup will be there but other then that the floor pans are so I can't see an issue.
If runner holes are needed then be sure to use some form of decent reinforcing when bolting in the seat as a washer will pull right through the floor if pushed.
It will really come down to what the seats are that you are trying to fit mate?? You need to give us a bit more detail of what you are trying to do? "Replacement Truck seats on my wagon" is a little vague? sorry mate...
As stated by Paul above they should nearly bolt straight up if you are trying to fit a GU seat into a GU? replacing a bench style for 2 buckets as per the original post?? GU seat into a GQ would be a whole other problem???
If it is GQ seats to a GQ then make sure you grab the rails to go with them and they should nearly go straight in, Gu to GU again grab the rails.
any other configuration give us some more details.
Cheers MR
Its a Nissan! =====> Its a Keeper!! ....... Got a TD42 in it BONUS!!....... I'm a lucky bugger! I've got 2 of em!
