Page 729 of 1057 FirstFirst ... 727728729730731 ... LastLast
Results 7,281 to 7,290 of 10566
  1. #7281
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Putting finishing touches to Titan draws , fridge plug was working it's way out so now Anderson plug .
    Current job is installing third battery which will go beside fridge on passenger side so will have main crank plus two 110 amp gel cell batteries in car and two 105? Amp in camper trailer , fridge in car 45 ltr will be used as a freezer , 60 ltr ARB in camper as a drinks and food fridge .
    Just finished the cooling fan to back of fridge mounting still have to put in the switch and the fridge switch and get proper tie downs .
    Setting up for desert trip in may / June .
  2. #7282
    .......... TPC's Avatar
    63 Post(s)
    You are going to have some trouble with those, you put them in upside down and everything will fall out.
  3. The Following 5 Users Say Thank You to TPC For This Useful Post:
    GQtdauto (2nd February 2017), neet_wagon (10th October 2018), Parksy (2nd February 2017), stevemc181 (14th February 2017), threedogs (14th February 2017)
  4. #7283
    Dec 2016
    Northeast Victoria
    41 Post(s)
    You mean the fuse panel ? Haven't decided on a location yet so it's temp .
  5. #7284
    Expert Patrol'n's Avatar
    Oct 2014
    WA
    Installed new Superior Engineering upper control arms including bent driver's side one. Next mod will be the Auxilliary belly tank me thinks. Should give me about 220 litres fuel capacity :-)
    93 GQ wagon, RB30, extractors, 2 inch tough dog lift, 5 spd, A/T KO2 32's, steel winch bar, rated recovery points, red arc dual battery set up, rhino roof racks, UHF etc etc. Slow and steady might not win the race but it gets me there eventually...
  6. #7285
    Patrol Freak Wine_maker's Avatar
    Nov 2011
    Kazakhstan, Almaty.
    8 Post(s)
    Just bought a set of stock coil springs from long GU, 2009 year. Looks very nice I think.
    Mate changed them to TJM +2"
    How they will be for short GQ?
    Am I right, that the higher front spring for driver side and there is no difference for rear springs?
    I'm Alexander and I'm the happiest owner of GQ Nissan Safari in the whole Central Asia
  7. #7286
    Getting a gas service done.
    The system that it has no body has the program to tune it, except for the guy that installed it and he's in Dandenong, 60ks away. Last one was done in June '14 a month after I bought it.
  8. #7287
    who installed it was it smithy's
    around the corner from Piranha and Brown Davis
  9. #7288
    Have you seen the Engel Transit bases, Ive had mine for years in 2 different 4x4
    can't praise them highly enough.
    I also fitted a digital thermostat might want to have a search about that one
    again a great mod imo
  10. #7289
    Nah, some small work shop that's been there for 30 odd years. He has the rights to the programe and won't give it to anyone. Pita lose a whole day.
    Throw up a knock sensor fault.
    Something else to do...
  11. The Following User Says Thank You to jay see For This Useful Post:
  12. #7290
    Patrol Freak garett's Avatar
    Jan 2015
    north
    21 Post(s)
    finally put on the other side step. only about 50 more things to get around too
