Results 1 to 10 of 45
Thread: GU Wagon GVM Upgrade
Threaded View
  1. #17
    Adventurist stevemc181's Avatar
    Jan 2017
    Thornlie,Perth WA
    8 Post(s)
    Quote Originally Posted by PBBIZ2 View Post
    Stevec,
    do you know what the actual front and rear spring rates are in lb/inch for your installation? I am trying to build a case for my suspension ratification in Victoria.
    thanks is advance,
    Phil
    Sorry mate I didn't get the actual spring rates from them. She doesn't ride as harsh as my NW Pajero and I've got 1250lb variable rate rear coils in the Paj, so I assume these are somewhere south of that
    I finally picked her up today! They have also changed the side indicators over to some larger ones, which is a bit of overkill, and I note the category has changed from MC to NB1 (for vehicles over 3.5t) I then drove her straight to the tyre shop and changed out the tyres for some Mickey T ATZ P3's in 285/70/17. There is some rubbing of the mudflaps I noticed on full lock in reverse, so I'll sort that out ASAP and remove or trim them.
    I've only had it a few hours and I'll be taking it back already unfortunately! Looks like they have stuffed up the install of the Eclipse SatNav. It doesn't matter if I am stopped with the handbrake on etc, I can't access most of the menu functions for navigation or Bluetooth etc. Pretty useless having a satnav I cant put an address in! I'll get on to them in the morning, other than that I'm loving it so far!
  2. The Following 5 Users Say Thank You to stevemc181 For This Useful Post:
    BigRAWesty (1st February 2017), Clunk (1st February 2017), Hodge (1st February 2017), PeeBee (1st February 2017), threedogs (3rd February 2017)
