Page 36 of 77 FirstFirst ... 3435363738 ... LastLast
Results 351 to 360 of 762
Thread: Jay see 1997 GU build up
  1. #351
    Got a link?
    http://www.clearviewmirrors.com.au/
    A fair whack dearer than the MSA one though.
  2. #352
    Don't really see much of a difference.
  3. #353
    You make a strap for the middle too John?
    Nah, I didn't.
  4. #354
    Patrol Freak Bacho86's Avatar
    Mar 2011
    14 Post(s)
    Pretty sure unleashed (or whateva pat callans mag is called) did a review comparison of the msa and clearview drop down slides last year.
    From memory they're pretty similar, think the clearview has a few other new features and weighs a fair bit less as well - but it does cost a few hundred $$$ more
  5. The Following User Says Thank You to Bacho86 For This Useful Post:
    jay see (31st January 2017)
  6. #355
    Nah, I didn't.
    You might find the centre of the drawers will pull up when the drop slide is loaded and pulled out.
    The MSA slide handle lifts up and over the fridge when you lower it. The Clearview fridge goes down. Not a big deal for most but for a shorty like me, and if your parked on a bit of a hill, it can be a task. Also I have found the handle hits the top section of the small barn door too when lowering. So I need to force the door open that little bit more for it to clear.
  7. #356
    I'm going to put it all in today and then see how it holds up. If a center point is needed will do it then.
    I think you might be taller than me lol.
    I reakon i can live with the MSA considering the the whole set up (draws, dropslide, cage and fridge) cost me $1600.
  8. The Following User Says Thank You to jay see For This Useful Post:
    mudski (31st January 2017)
  9. #357
    Stage 2 complete.
  10. #358
    Should I be running all negatives to a buzz bar or just earth them to the closest point.
  11. #359
    Depends on what it is I suppose. I try to have a common earth point in different sections of the car. Only for trouble shooting if need be really.
    jay see (1st February 2017)
  13. #360
    Winch switch sorted. Just need to do a simple switch on the bar and some light for the isolator.
  14. The Following 4 Users Say Thank You to jay see For This Useful Post:
    Family4x4 (1st February 2017), MB (19th February 2017), Mike02Ti (1st February 2017), Rossco (1st February 2017)
