Page 722 of 1057 FirstFirst ... 720721722723724 ... LastLast
Results 7,211 to 7,220 of 10564
  1. #7211
    198 Post(s)
    Made bracket for new aux 200amp alternator and fitted it. Looking to wire it tomorrow if i can get some answers on the termail designations - posted in electrical.DSC01733.JPGDSC01734.JPGDSC01735.JPG
    threedogs (23rd January 2017)
  3. #7212
    Quote Originally Posted by PBBIZ2 View Post
    Looks very neat well done, why the need for the extra amperage ????
    PeeBee (23rd January 2017)
  5. #7213
    84 Post(s)
    I was wondering the same thing. TD.
  6. #7214
    198 Post(s)
    Wanted the grunt for the rear battery in the main when using the rear winch warn 15000lb in the rear bar. Trying to protect against deep discharge.
  7. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    mudnut (23rd January 2017), threedogs (23rd January 2017)
  8. #7215
    84 Post(s)
    Are you going to run the second alternator all the time, or are you gunna slip a belt on before you go offroad?
  9. #7216
    Patrol Guru
    Jul 2014
    6 Post(s)
    This was for saturday, but new rotors and pads all round, repacked cv's, new front wheel bearings, few other bits. Still need to change rotor button in dizzy, redo the timing and seal up the dizzy cap again. Plus add dielectric grease to the ignition lead boots, and finally bleed the brakes as I mistakenly let the master cylinder run empty (car was still on an angle from pulling the cv's). Fun and games.
  10. #7217
    198 Post(s)
    Its hooked up all the time. I asked a similar question on this forum regards temp isolation, and the answers came back back along the lines that it will only charge to the state of discharge anyway, so over-charging is not an issue. I guess I am 'wearing out' two for the price of one, but in the end its simply a bearing/brush issue regards life, and this vehicle would not see 2000 klm/yr at most. There is no apprecaible extra noise when driving and can't detect any loss due to additional belt drive - if it was on the original 2.8TD it probably wouldn't get off the line!
  12. #7218
    198 Post(s)
    Swapped over aux. fuel tank solenoid valve as it had finally died after 19 years of use - not bad service I reckon. Dirty awkward job in the heat, in the garage, at ground level, covered in diesel - oh the joys!
  13. #7219
    left it on the front lawn after it looked at me in disgust
  14. #7220
    Patrol Freak garett's Avatar
    Jan 2015
    north
    21 Post(s)
    put an extra horn on it .. sounds beautiful
