Page 47 of 136 FirstFirst ... 4546474849 ... LastLast
Results 461 to 470 of 1356
Thread: All Things Chev
  1. #461
    Quote Originally Posted by PBBIZ2 View Post
    OK, have the dual vee pulley installed, bracket in place, belt sorted out and DCV mounted ready for the hose guy. Couple of picks. The DCV is mounted behind the winch, which gives good access for installation, direct to winch and at the right height for the reservoir. Hope this helps PhilAttachment 70359Attachment 70360Attachment 70361
    Bit of an update. The 2" pulley did not have enough surface area and would slip when the pump was idling, probably a combination of diameter and material(aluminium.) I have since changed this to a cast iron pulley of 3" PCD and much better outcome. The speed is slower, however I made a simple throttle lever to increase speed to circa 750rpm and the line speed is in the range of 4.5 - 6m/minute which is fast enough for what I use it for, and it will do this all day without effort if required.
  2. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    MB (18th January 2017), rainsey (14th January 2017)
  3. #462
    OK, back at square 1 again. Sump replaced, springs replaced, alternator replaced, added new Safebrake brake lines, hydraulic winch sorted and operational, working on mounting the additional 200a alternator and endless air compressor over the next week or so, then ready to start getting out again! Can't wait to be honest.
    Only thing outstanding is valid GVM documentation from WA.
  4. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    MB (18th January 2017), Ropes (17th January 2017)
  5. #463
    Nov 2010
    Getting a life...
    38 Post(s)
    I have a general Q. SteveO's got a G60 with a 350 chev in it, it needs replacing. Whats the best option ? I'm told we can get a crate motor landed in Thomastown ( melb) for about $2500.
    KATROL- The 2nd
    GU TD42TGi
    Silent member 1208
  6. #464
    We used to get Chev's and Clevelands from Eagle Auto Spares on the South Gippsland hwy Dandenong, its been a long time so not sure what they're still like or pricing these days. They always had donks in stock for quick changeovers in the old days.
  7. The Following User Says Thank You to MB For This Useful Post:
    katwoman (18th January 2017)
  8. #465
    Crate motor will be easiest. Pretty sure the mob MB mentioned still do quite a bit of this gear. They really arent that dear to rebuild either unless the block is shagged. Good time to take it out to 383 or 400ci....
  10. The Following 2 Users Say Thank You to nissannewby For This Useful Post:
    katwoman (18th January 2017), MB (18th January 2017)
  11. #467
    And a turbo
  12. The Following User Says Thank You to nissannewby For This Useful Post:
  13. #468
    Nov 2010
    Getting a life...
    38 Post(s)
    And a turbo
    It's already turbo'ed.
    KATROL- The 2nd
    GU TD42TGi
    Silent member 1208
  14. #469
    Really?
    Where are the pics?
    It doesn thave something like a turbo 350/400?
  15. #470
    Steve and matty should really meet up Kat
    If you think you're broke now whoaaa mumma it would be epic
  16. The Following 2 Users Say Thank You to AB For This Useful Post:
    katwoman (18th January 2017), Winnie (18th January 2017)
