Results 1 to 10 of 17
Thread: Vms mounting position
    May 2016
    Walla Walla NSW
    G'day fellers just wondering if anyone has made or bought a different mounting system for there off road gps. I'm not a fan of having it on the windscreen due to the blind spot.
    Aug 2014
    Perth
    10 Post(s)
    I haven't bought one yet but I have seen ones that use the bolts in the seat rails to hold the flexible arm in place.
    Quote Originally Posted by gubigfish View Post
    @mudski has one of those and it seems pretty good.
    I have a GUIV which is the same and all GUs from GU4 up and i have a RAM Mount fitted into the top glove box where the factory GPS is supposed to go. From that i mount an iPad in a RAM Mount and its been bloody good.
    @mudski has one of those and it seems pretty good. I have a GUIV which is the same and all GUs from GU4 up and i have a RAM Mount fitted into the top glove box where the factory GPS is supposed to go. From that i mount an iPad in a RAM Mount and its been bloody good.
    is yours a similar to my ram mount I used for satphone?
    Does it shake much?
  5. #5
    Does it shake much?
    Not at all mate. it has been great. It rests on the ledge though too so heaps of support. the arm is 150mm long i think and it hangs down so i can't see the radio too well but its all good.
    I could probably place something under it to lift it up out of the way but it has not been an issue so far
  6. #6
    So the iPad RAM Mount i have is designed to take an iPad size tablet and stretches at each end then clamps the iPad firmly. Ball joint on the back clamps to the mount
  7. #7
    Any photos and price?
    Once finances get back in order this is s must for me I'm just throwing my iPad on the passenger seat and constantly stopping to check, annoying yes, convenient No!
  8. The Following User Says Thank You to AB For This Useful Post:
    gubigfish (16th January 2017)
    May 2016
    Walla Walla NSW
    Mine is a series 1 so no top glove box. Forgot to mention that
  10. #9
    Aug 2011
    River Heads Q
    4 Post(s)
    Mine is mounted at top of windscreen next to rear vision mirror with power lead running across passenger's sun visor and then down to dash via grab handle.
    One day I'l get around to supplying power from above roof lining. Works really well and is nice and close to see easily and to change maps or zoom in and out. Would be legal as well as it is still level with bottom of sun visor and does not restrict vision.
    Will post photo when I go down to the shed.
  11. #10
    Patrol Guru TimE's Avatar
    Canberra
    Check my write up here RAM mount with 10" tablet
  12. The Following User Says Thank You to TimE For This Useful Post:
    AB (17th January 2017)
