Results 1 to 10 of 11
Thread: Any thoughts on these ??
    http://shop.snakeracing.com.au/exper...recovery-hook/
    Anyone using one of these?
    Or these
    http://shop.snakeracing.com.au/black...ry-winch-hook/
    Or this style
    http://shop.snakeracing.com.au/red-p...tv-winch-hook/
    Will save having that first foot being blasted by road grit all the time.
    I covered mine in 3/4 split tubing
    First device I can see an application for the comp boys
    The others?
    Well, I don't use a winch hook anyway just attach my winch cable eye to the Bow shackle so using one of those just introduces another bit of kit and gives the manuf a hunjy or two
    I spose the shear pin might add some safety then again maybe not... would kinda depend on the scenario
    Really? Seems like they would have to use a shackle which they don't like because they're too slow
    Patrol Guru sooty_10's Avatar
    Bendigo
    7 Post(s)
    I have a very similar end on my winch rope which i simply attach a shackle through it to the tree protector when winching. Ill grab a photo of mine this morning for you.
    I believe mine is actually spliced on and doesn't use a shear pin at all. The rope will break before the end comes off so it will still be secured to the shackle and tree protector.
  5. The Following User Says Thank You to sooty_10 For This Useful Post:
    threedogs (25th September 2015)
    Dec 2016
    Yarrabah
    Was wondering where to get those from
    177 Post(s)
    Quote Originally Posted by FNqGu04 View Post
    I have one that arrived with my Runva winch. Just search winch thimble on eBay there are a few including the Runva ones.
    @Hodge do you think its legal/safe sticking out like that ??
    Certainly is one of the neater options out there
    http://www.ebay.com.au/itm/Runva-Alu...EAAOSw44BYeqEX
    177 Post(s)
    http://www.ebay.com.au/itm/Runva-Aluminium-Winch-Thimble-Winch-Thimble-/252660136403?hash=item3ad3b7b9d3:g:6GEAAOSw44BYeqE X
    Don't know John, about legality. It isn't sticking out past the furthest front point of the b. bar.
    84 Post(s)
    Now that is a point, Pardon the pun. I would suspect it would be held flat against the bar by the rope pressure, would it not? It also eliminates the need for exposing the rope or cable to damage and UV rays.
  11. #10
    177 Post(s)
    Yes it is held up against the hawse when the rope is taut. The black rubbery covers prevent it from sliding all over the place . Very neat.
  12. The Following User Says Thank You to Hodge For This Useful Post:
    mudnut (15th January 2017)
