Results 1 to 10 of 12
Thread: D I Y fitting 3 inch exhaust
    Aug 2016
    Broken Hill
    Guys need help
    how far of the ground does my patrol have to be to fit the engine pipe without removing the swaybar
    cheers
    Expert billyj's Avatar
    gordon
    without knowing what engine/turbo/exhaust its a bit like asking how longs a piece of string
    that said i fitted a heavily modified 3" system from a gu zd30 to my gq tb42e turbo in a couple of hours without lifting the vehicle off the ground exhaust was built in 3 pieces
    Unafordable
    4 Post(s)
    No need to lift the car up mate, however if yours is ZD30 powered then the OEM dump pipe/DOC (Diesel Oxidation Catalyst) will not come off unless you drop LH side of the sway bar (front).
    Regards
  4. The Following 2 Users Say Thank You to Rumcajs For This Useful Post:
    OuchOne (5th April 2022), threedogs (27th January 2017)
    Aug 2014
    Perth
    10 Post(s)
    When trying to get the dump of mine to fit the port for the EGT gauge sensor, the exhaust couldn't be got to without unbolting the swaybar properly, soon as this was done it was a much easier job.
    177 Post(s)
    I had no issues when fitting a 3" system to my 2009 Crd. Just had the car on stands, so the front wheels were just off the ground. I'm sure I didn't have to get anything out of the way. The big bitch is the exhaust studs... I invented new swear words during fitting on both the 3L and the 4.2L.
  7. The Following User Says Thank You to Hodge For This Useful Post:
    Aug 2016
    Broken Hill
    thanks guy's
    I should have mentioned 2014 zd30 patrol and a redback 3 inch exhaust
    Patrol Freak Bacho86's Avatar
    Mar 2011
    14 Post(s)
    Quote Originally Posted by driller View Post
    thanks guy's
    Interested to hear how you go fitting the redback - I'm ready for an exhaust upgrade but still tossing up options (2.75" vs 3") / brands etc
  10. #8
    Aug 2016
    Broken Hill
    thanks for feedback and will let you know how I go I have a set of ramps and will use them
    cheers
  11. The Following 2 Users Say Thank You to driller For This Useful Post:
    Bacho86 (12th January 2017), growler2058 (12th January 2017)
  12. #9
    Aug 2016
    Broken Hill
    Well finally finished
    what a bloody job it would be easier if you have small hands and getting the turbo heat shield off was an adventure
    as im retired the time frame didn't concern me but if its your only vehicle and needed every day might be a different story.
    I had to take the sway bar off on the passenger side and push it back then under the engine pipe as it was different length to OEM one.
    I am happy with the difference tho as the car pulls better now.
    cheers
  13. The Following 4 Users Say Thank You to driller For This Useful Post:
    AB (26th January 2017), Bacho86 (27th January 2017), BigRAWesty (27th January 2017), threedogs (27th January 2017)
  14. #10
    cheers
    I took the actuator and mount off.
    That made the removal of the heat sheild much easier..
    And yea sway bar off makes it much easier to install the dump pipe.
